Thermostat motor M207
Moderator: UMMM461
UMMM461
Post by UMMM461 » 19 Sep 2014, 20:27
You can see in the picture the original thermostat and the Vernel equivalent.
Identical as dimensiuon is :
VERNET producer code 1309.82
Al little smaller thermostat but it is bolt on if you use the provided rubber gasket is :
VERNET producer code 4608.80
Opening temperature is 80C
