PARTS COMPATIBILITY FOR ARO10 Please help
icemann
Re: PARTS COMPATIBILITY FOR ARO10 Please help
Post by icemann » 29 Nov 2012, 12:09
SorinTVY wrote:check beering for wear, ""piting", no shaft play(feel by hand) are not allowed ,when the ghear box was "siel'd",
the rolers on the triax front shaft hosing , if no play exisst, end the triax is not mooving inside the housing, just cleen the old gres, the conexion shaft betwin the weel end diferential , musn't be play betwin ,the sfat..end the weel part -housing-rollers., if ar worn owt, must bee made new roollers, (hard steel like sprochets in the geearboxes- ), theat all,...
ruber housing for the shaf, renault 12 will fit, but deepends,.. you chan use universal ones,
there was no play in the gear box,
i`ve oppened the front axles they look ok. no play or wearing off. i will change the rubbers and assamlbe them again.
Sorin i`ve read this post.
http://www.aro4x4.net/smf/viewtopic.php ... &start=105
but i cant understand about the shocks.. dacia Oem but from which dacia.. which model which year.. i would like to buy them but in the shop they asked me from which dacia..
icemann
Post by icemann » 10 Dec 2012, 22:34
after cleaning i have found out that the front axle is damaged on the place where it fits the bearing... can you tell me if there are front axles that fit the aro or i will have to repair it?
Post by Soryn » 10 Dec 2012, 23:11
make picture, dacia/ R12, fits but the weel part it's smaler, end short.!
icemann
Post by icemann » 28 Mar 2013, 16:21
hey guys,
i got the new gear after many months in production..
i`ve finished assembling the transfer case and i`m ready to attach it to the gearbox as soon as i find that nut from VW transporter to bolt it all together.
i need information about the oil that should go in the transfer box, gear box and deferentials.
i`ll upload some photos later :)
Post by Soryn » 28 Mar 2013, 17:38
icemann
Post by icemann » 29 Mar 2013, 01:01
10x sorin :)
icemann
Post by icemann » 26 Jun 2013, 14:48
icemann wrote:10x sorin :)
Sorin Do you know if there is another car that fits the same stabilizators and the rods that are connected to the front wheels.
the rubbers are destroyed and i cant find the rubbers for aro.
icemann
Post by icemann » 26 Jun 2013, 15:00
i need these parts.. how to search them?
Post by Soryn » 29 Jun 2013, 09:26
2x ruber busch with 19 mm hole
in romania is difficult to find ruber parts for the car's becouse rubber factori's are dead closed
i thinck wil fit some buschins from other car, but we must serch by the pictures end schematic drowiing .
is hard but not catastrofic.
icemann
Post by icemann » 20 Aug 2013, 12:44
This is the progress so far..
i`ve bought 15inch rims and 205 70 15 tires.. i still think they are small. the front looks little bit lower but i need to measure it on a flat surface..
now i need to put the brakes bleed them, and work in the interior..
also im without front diff i`ll be only with rear for some time.. and insert the front diff later..
for the blinkers i`ve made parts from polyester and bought land rover lights.. the original are broken and finding new in here is impossible
icemann
Post by icemann » 24 Aug 2013, 21:41
sorin i`m trying to fix the brakes but i have problems with the main cylinder or break pump... i need schematics i think i made mistake with the rubber parts in the pump..
i need some assembly schematics in order to fix it..
thanks..
icemann
Post by icemann » 26 Aug 2013, 13:44
i`ve bought new break pump from R4 R11 and i fitted it.. it works ok.. i now have break system..
but i still would like schematics for the old one.. i would like to fix it and keep it for spare parts..
pictures later this day
icemann
Post by icemann » 21 Oct 2013, 14:47
Here are some progress pics.
i desided to create side blinkers from fiberglass.
this is just to see how it will look.
than i created models from gips.this is radicol material for gluing drywall panels.
than i created negative mold from the same material
icemann
Post by icemann » 21 Oct 2013, 14:51
This is the part from the negative mold.
after some cutting and rough sanding and gluing to the black cover for the headlights.
after covering it with kit.
icemann
Post by icemann » 21 Oct 2013, 14:55
This is with sanded kit and lights fitted.. ready for paint.
this is covered with filler.
and final product.
