Questions about ARO
Maxim
Questions about ARO
Post by Maxim » 12 Jan 2008, 06:40
Talk me , please - in what a difference between L27 and TDX28 (except for the turbine)? It is interesting to know.
pantelimon
Re: Questions about ARO
Post by pantelimon » 13 Jan 2008, 09:12
chiulasa - setul motor -pompa de injectie si cam atat
silvester
Post by silvester » 13 Jan 2008, 10:30
pantelimon wrote: chiulasa - setul motor -pompa de injectie si cam atat
Engine kit, injection pump and cilinder head (i supose), says Pantelimon.
Post by Werner » 13 Jan 2008, 12:35
The TDX-28 engine has a Garret Turbocharger.
Maxim
Post by Maxim » 13 Jan 2008, 17:43
Please, it is possible more in detail, is especial about engine kit.
Maxim
Post by Maxim » 14 Jan 2008, 17:04
What sizes in the standard (for L 27) :
1. rod shell
2. main shell?
Whether there is an analogue of this motor (for selection of analogues of spare parts)?
Maxim
Post by Maxim » 15 Jan 2008, 17:31
Questions without replys....One , as  in desert... ??? Excuse me please what such comparison...
Geronimo
Post by Geronimo » 16 Jan 2008, 14:41
Priviet Maxim
Long time ago i have bought L 27 documentation because of I made mistake, item description was I27 and I fought that is 127 ï
Maxim
Post by Maxim » 13 Mar 2008, 05:48
What sizes for crankshaft sealing (front / rear) L27 engine?
Maxim
Post by Maxim » 20 May 2008, 15:43
Good day AROusers and AROlovers!
Who can to make foto of the piston BRASOV 102 mm (from combustion chamber side). I am want to know what form to have the chamber, its disposition , by the ratio to central axle, if one can - to measure diam of chamber. Please!
Maxim
Post by Maxim » 27 May 2008, 07:08
Even tell me where disposition the combustion chamber at BRASOV 102 mm (D115.050-054, D127.050) - is located on the centre or not?
For example - on 127.005 (95 mm) chamber of combustion is displaced on 5 mm from
the central axis. It is necessary for me, for repair of the motor of my car. I shall increase diam of the cylinder, I need to pick up suitable pistons. Suitable (on first look)- from FIAT 8004.02 (100 mm) , but wanted to know as looked the piston from BRASOV 102 mm.
Please!
Maxim
Post by Maxim » 27 May 2008, 12:12
View of piston for FIAT8040.02 (100 mm)
Maxim
Post by Maxim » 27 May 2008, 12:40
View of piston for SAVIEM 98mm and 102 mm. Absolutely another the combustion chamber form. Absolutely another nozzle ( short size, one hole ).
Maxim
Post by Maxim » 29 May 2008, 06:47
        SAVIEM      FIAT/UTB    FIAT
Piston diameter                                                            98.000  102.000  95.000    100.000
compressional height  (inaltimea de la centr.bolt
          alezajului pt.bolt pana la capul pist.)                      75.38    75.58    59.650    59.650
piston lenght  (inaltimea totala)                                      119.38  119.58  101.100    101.150
comb.chamber depht                                                      36.65    37.95    23.500    23.700
piston pin lenght (lugimea pentru boltul)                            84.000  86.000  84.000    84.000
piston pin diameter (alezaj pentru bolt)                              36.000  36.000  32.000      32.000
all dimensions in mm.
nozzle for SAVIEM        - DLL 18 S 418, DLL 18 S 169
nozzle for FIAT/IVECO/UTB 95mm                                            - DLLA 145 S 448
nozzle for UTB 115, 121(050-054) and FIAT with big bore            - DLLA 141 S 662
Maxim
Post by Maxim » 24 Oct 2008, 18:37
Hi all AROusers!
What was diameters of brake drums???????
On my cars - 280 mm front/rear
User, from another city said - 254 mm  :o
All cataloges give size 228 mm (even for ARO 240/243/244 2.5 2.5D 3.1D LCV 10/1974 - 12/1993)?!?!?!?!  :-??
That to trust????? Per what years was the sizes varied?
Who is know brake shoes analogues (from another cars) for drums diam 280 mm?????? :'( ^:)^
