Hi. I got my new thermostarter in the mail, but now the engine is getting no fuel even though the tank is full. I haven't started the engine in 6 months. Any idea what the problem is and how I can fix it? Any suggestions would be appreciated!
Jason
help! engine gets no fuel...
Moderator: UMMM461
- Jason T
- Nou venit
- Dan CHIRIAC
Re: help! engine gets no fuel...
Since the engine was not started for a long time, there might be air in the fuel system.
You need to make sure all the air in the fuel lines all up to the injection pump, and then towards the injectors is eliminated. Here's the drill.
1. Fuel filter(s) - they have a screw for letting the air come out, just manually engage the fuel pump
2. Injection Pump - has two small screws, open the first, engage the fuel pump, Open the second, turn the key - it doesnt work if you only use the fuel pump.
At this point the engine should start. If not, tighten all the screws and slightly loosen an injector. Turn the key. Again - it should start.
If you give me a few pics of your engine I can perhaps indicate what needs doing where
- Maxim
Hi Jason!
Try:
1. To remove air from fuel system, consistently, filter 1 - filter 2 - the injection pump case, through the bolts, intended for it.
2. After filling system by fuel (absence of bubbles of air in fuel) to start the engine through a tow (other automobile). It is "illness" of all motors with LUCAS-DPA pump - after hit of air in system the first start is not always possible with the help starter.
Try:
- alex
then u might want to consider other pssible causes of dirt jamming/air in the fuel lines.
1-hint-replace the fuel line from injection pump to the filter with a transparent fuel line-so u can notice air bubbles
2-check the membrane from teh fuel pump or whethever its functional as a unit(if filter can be filled while pumping manually it should be ok, but ive seem pumps having their lever getting jammed for no obvious reason)
3-air existing in the sistem, go towards the fuel tank and look for loose joints on the pipes ( I just changed the whole line with a new fuel line)
4-the fuel intake metal pipe located in your tank can get cloged with dirt and can present a valve like problem. engine starts and soon stops.
hopefully u have the easiest problem, ie need to get the air out from the injection pump.
after u open and close the first screw on the pump,u open the second, ask another person to turn the key so the starter will rotaet the engine and sometimes I lift just a bit the acceleration lever. good airing of teh sistem should happen when fuel starts sprinkling at the screw and about teh same time teh engine should start. no fuel coming out there u have to go backto the first steps.
