Modes of transfer gear-box???
Moderator: UMMM461
- Michael
I don`t mind. How can work transfer gear-box on my car! How much has mode of transfer gear-box? I need instruction for use transfer gear-box. I have this is kind of transfer gear-box. (looking on pictures)
Re: Modes of transfer gear-box???
i think , it's this one
main transmision 1-4 + R , transfer box 4x2= just the rear weels , 4x4L = rear end front weels in slow speed (redus)( loots off torq), 4x4H front & reear weels in hii speed(butt less torq)
poure english
your transfer box , may nott want tu change ghears ,or , it's possible to ghet stuck in 4x4 mode
poure english
- Michael
4x4L How is max speed?
4x4H ?? max speed? up to 100-120km/h???
thanks for the plate.
Michael wrote:4x4L How is max speed?CT-03-TVY wrote: i think , it's this one
poure english ;)
in 4x2 mode, just in this mode the car chan reach top speed 100-120 km/h
in 4x4H it's not good for the transmision to reach seeds of 60/70 /Km/h
in 4x2L mode, the car ,chan reach top speed of 40/50 km/h
THE EXCESIVE Speed It's not good for all transmision parts in movement
in the past my car ,from the excesiv speed, 70/80Km/h in 4x4H mode, the front differential borke down
- Michael
OK. I have one moment. I think 4x4H mode has been broken, because max speed up to 40km/h. If I`ll open transfer gear-box case (cover of hole) then 4x4H is ON? What do you think about it?
if the max speed you chan reeach neaw , with the transfer box stuck , is 40km/h, theat means theat the box is stuck in 4x4L, you chan acces the visit window (cover) end look in side, end you chan adjust the mecanisms, until the ghear stick/transfer box,changes ghears, in 4x4L,4x4H,..end Normal 4x2(back weels)
if the pinion's inside ar not deteriorated, if they are , you must reconditionate the holle transfer box
- Michael
I`ve understand. I`ll look inside.
what do you have engine? 1,4? engine block without a crack?
no , y have an 1.6 D vw&audi provenience, its lowned from vw Golf 1 by the factory, but the transmision's is the same, just the cover ,theat conects the transmision to the engineMichael wrote: I`ve understand. I`ll look inside.
my 4x4 sistem was dameged , some many yar's ago , my fox, was driving the car then, end now, i'm triing to rebuild the transmision sistem,... y both the part's for the front axel,
you dont recongnise my car from yotube site ,we spoke then ,by email
- Michael
Could you give me link? On youtube.com
I`ve seen there very very much video with ARO.
What is engine name? (in VW or AUDI catalog)
I have 1.4 engine.
Its B14.0 - volvo
and C1J, С2J - renault
I have 1.4 engine.
Its B14.0 - volvo
i dont know wath the engine code is , but in the registration notebook of the car, at engine specifications, says Wolkswagen 827 , the same engine was giwen ...to the ww golf 2 , but with the code Jp ,JK, SB alll wih the same displecement ,lyke myne 1588 cc , but the fuel sistem is a littel diferent , to produce more Hp, by exampel, SB engine 1588 cc , have foreced induction (TURBO) end an intercooler ,end the injection phump , haz a Fuel Regulator controled by the Turbo actuator, end produces 80 HP,
the engie bloc end the valve train is the same
my engine is normaly aspirated, end has 54 Hp ,
morning start, cold http://www.youtube.com/watch?v=X6OPc3VKGKI
sow, 1588 cc Diesel , Engine code JP vw&audii (is the same,..but my engine dozent have this code becouse is made in Brasil .end imported by the factory in romania)
- Michael
Oh it`s you. Ive seen video. And I`ve asked you on youtube.
- Michael
Now 4x4 is working.
I have changed position detail up about 2 mm
Thats all !!!
PS. Where I can find universal joint cross of front cardan? Maybe I can find from others europ car?
Thats all !!!
nice work pallMichael wrote: Now 4x4 is working.
Thats all !!!
i hope you flush the rusty oil(brawn) from the transfer box,end stuk in to it new fresh transmision oil,becouse look's bad,
- Michael
of course! I`ll use new transmission oil
