Motorizari ARO
Motorizari ARO
Post by George » 03 Feb 2007, 20:31
TOYOTA:
In anul 2000 Toyota Motor a avizat montajul motorului turbo diesel 2 L-T pe automobilele ARO din gama 24x,dupa ce,in urma cu un an,firma japoneza a aprobat echiparea acestor automobile cu motorul pe benzina 2 RZ-FE. Acordul semnat atunci permitea comercializarea vehiculelor atat in tara cat si in strainatate cu inscriptionarea "Motorizat de Toyota"
Raspuns: Motorizari ARO
Post by George » 06 Feb 2007, 10:25
ANDORIA
Motoare fabricate in Polonia,dupa licenta englezeasca.Pe aro s-au montat urmatoarele tipuri:
4C90 - 2417cmc - 51,5kw / 4200rpm - 146Nm / 2500rpm;motor aspirat,injectie indirecta
4CT90-1 - 2417cmc - 66kw / 4100rpm - 195Nm / 2000÷2500rpm;motor turbo,injectie indirecta,Euro2,pompa injectie BOSCH sau MOTORPAL
4CTi90-1BE - 2417cmc - 75kw / 4100rpm - 230Nm / 2000÷2500rpm;motor turbo,injectie indirecta,Euro3,pompa injectie BOSCH.
Post by George » 11 Feb 2007, 11:33
ARO L25
Benzina CO R90,4 cilindri in linie,racire cu apa.Alezaj/cursa(mm) 97/84,4,cilindree 2495cmc,raport de compresie 8:1,cp 83/4200rpm,cuplu 173Nm/2900rpm
ITB D-127 (Brasov)
Diesel in 4 timpi,injectie directa,racit cu apa,4 cilindri in linie.Alezaj/cursa(mm) 95/110,cap. cilindrica 3118cmc,raport de compresie 17:1,cp 65/3200rpm,cuplu motor 186Nm/1600rpm.
MagnuM
Post by MagnuM » 12 Feb 2007, 01:58
Motorizari romanesti:
M-207, 4 cilindrii in linie, alezaj x cursa: 97 mm x 85 mm, capacitate cilindrica: 2513 cmc, putere: 70 CP, cuplu motor: 16 daN, aspirat, benzina.
L-25, 4 cilindrii in linie, alezaj x cursa: 97 mm x 84.4 mm, capacitate cilindrica: 2495 cmc, putere: 80 CP, cuplu motor: 16.7daN, aspirat, benzina.
L-25, 4 cilindrii in linie, alezaj x cursa: 97 mm x 84.4 mm, capacitate cilindrica: 2495 cmc, putere: 83 CP, cuplu motor: 17 daN, aspirat, benzina.
L-30, 4 cilindrii in linie, alezaj x cursa: 102 mm x 92 mm, capacitate cilindrica: 3007 cmc, putere: 95 CP, cuplu motor: 19.6 daN, aspirat, benzina.
L-27, 4 cilindrii in linie, alezaj x cursa: 97 mm x 90 mm, capacitate cilindrica: 2660 cmc, putere: 68 CP, cuplu motor: 13.8 daN, aspirat, Diesel.
DX-28, 4 cilindrii in linie, alezaj x cursa: 97 mm x 90 mm, capacitate cilindrica: 2660 cmc, putere: 71 CP, cuplu motor: 15.2 daN, aspirat, Diesel.
TDX-28, 4 cilindrii in linie, alezaj x cursa: 97 mm x 90 mm, capacitate cilindrica: 2660 cmc, putere: 87 CP, cuplu motor: 19.1 daN, turbo, Diesel.
D-127 4 cilindrii in linie, alezaj x cursa: 95 mm x 110 mm, capacitate cilindrica: 3119 cmc, putere: 68 CP, cuplu motor: 18.1 daN, aspirat, Diesel.
MagnuM
Post by MagnuM » 12 Feb 2007, 02:08
Scurt istoric al evolutiei motoarelor romanesti - pentru a intelege de ce apare de doua ori L-25:
Motorului de M, i se spunea "jumate Carpati".
SR-ul, caci despre el e vorba, avea un motor, dezvoltat pe baza unei licenta Ford Y, cu 8 cilindrii in V - SR-211. M-ul a luat un rand de cilindrii de la acest model de motor si a dezvoltat motorul M-207, care a echipat modelele M, incepand cu M 59-B, pana la ARO M 461-C.
SR-211: V8 97mm x 85mm 5025cmc 140CP 32daN benzina
M-207: L4 97mm x 85mm 2512,5cmc 70CP 16daN benzina
Ulterior, cursa a fost redusa de la 85mm la 84.4mm si cu cateva modificari... a devenit L-25.
L-25: L4 97mm x 84.4mm 2495cmc 80CP 16.7daN benzina
Si dupa alte modificari...
L-25: L4 97mm x 84.4mm 2495cmc 83CP 17daN benzina
Pe baza motorului 'jumate Carpati' (acelasi bloc motor), dar cursa marita de la 85mm la 90mm, a fost dezvoltat motorul L-27, diesel-ul de Campu Lung.
L-27 L4 97mm x 90mm 2660cmc 68CP 13.8daN Diesel
Acel L din fata numarului de cilindrii (L4), reprezinta asezarea lor: in linie.
motorus
Post by motorus » 22 Feb 2007, 18:00
Printre altele : (Date incomplete sau poate incorecte )
pt seriile 2xx, 3xx
Toyota        2L-T        2446cmc
Toyota        2RZ          2438cmc
Hyundai      D4BF-E      2477cmc
Peugeot        P158        2498cmc
pt seria ARO 1x.y
Renault  F8Q - A6      1870cmc
Renault  F8Q - 248      1870cmc
240 / L 25 & 240 / L 27D - vandut & 244 / Peugeot
pupi
Post by pupi » 23 Feb 2007, 09:28
aro 10
motor renault 5 sau 11 1400 benzina 85 cp
fara alte modificari
zbor la treaba
4x4 is my way
ProDesign "Thema" D.H.V.2
SUZUKI DR 350 SE
ARO 10.4 Powered by Renault
cryba26
Post by cryba26 » 15 Mar 2007, 20:38
Stie cineva, motorul turbo diesel TDX 28 respecta normele de poluare Euro 2?
Post by George » 15 Mar 2007, 20:40
cryba26 wrote: Stie cineva, motorul turbo diesel TDX 28 respecta normele de poluare Euro 2?
raspunsul este:da
cryba26
Post by cryba26 » 15 Mar 2007, 22:42
sau Euro 3?
Post by George » 16 Mar 2007, 07:57
cryba26 wrote: sau Euro 3?
sau nu...  ::)
ajunge 2,nu deveni pretentios...
diesel euro3 pt ARO,daca vrei...Andoria 4CTi90,turbo intercooler,4500eur+tva.nou,0km.  :-*
pantelimon
Post by pantelimon » 16 Mar 2007, 10:14
domle da ce valori bengoase are L30-u ala *-:)oare s-o mai gasi pe undeva?si o consuma mai mult ca L25??
adiR
Post by adiR » 16 Mar 2007, 10:35
pantelimon wrote: domle da ce valori bengoase are L30-u ala *-:)oare s-o mai gasi pe undeva?si o consuma mai mult ca L25??
eu acum "aud" prima data ca exista un motor romanesc de 3litri :)
probabil ca atunci cand a aparut era... varianta sport :)
acum deja e depasit, doar 95 CP... si consum presupun destul de mare...
Post by George » 16 Mar 2007, 11:02
nu te mai uita numai la cai...vezi si la cuplu,care e mai mare decat la BV !! adica demaraj belea. plus ca e supus perfectionarii,il poti urca usor si in putere ;)
@stef: fara tva! dar de ce te miri? e vorba de un motor destul de performant si modern...turbo intercooler,care s-a facut si cu gestiune electronica,insa se ridica mult mai mult costul lui. la altii cat crezi ca e un motor comparabil? ia vezi un Ford de 2,4 TDDi,de ex.sau un pejo de 2,5 hdi
Post by George » 21 Mar 2007, 08:51
hagi_nicovici wrote: As dori sa-mi recomandati un mecanic care sa-mi monteze un motor de Peugeot pe Aro 244 cu motor de Campulung?? Daca cunosateti preturi informative??
asta nu e treaba de un singur mecanic...parerea mea.
si ai grija ca motorul sa fie unul din cele doua care s-au pus din fabrica,daca vrei sa il treci si in CIV,ca altfel te sparge RAR-ul la omologare. X3D,X3DT parca,sau asa ceva...sunt codurile de motor respective.
de costat,te costa undeva la 10 mil,cu adaptari cu tot. problema ar fi in carcasa ambreiajului,daca mergi pe cutia de ARO,ca nu prea se mai gasesc. daca iei motorul,cauta cu tot cu carcasa de ambreiaj
