BRASOV
Maxim
BRASOV
Post by Maxim » 31 Jul 2008, 17:59
The installation of "new" BRASOV is completed. All works have required almost two months. Besides replacement of the engine, as well, I did the auditing the gearbox and tr.box, and  replaced ALL operational liquids.
About of liquids:
motor oil _________ BP Visco 3000 10W40
transmission oil ____TNK-BP 75W90 (semisintetic)
antifreeze_________COOLSTREAME (made in Russia)
powersteering______Dextron-III CHEVRON
brake sistem _______brake liquid DOT 4 (ROSA, Russia)
Common cost for the car  ~ 120 euro
About of the engine , I will write here; about gearbox and tr.box - in "TRANSMISSION".
Re: BRASOV
Post by vstef_is » 31 Jul 2008, 18:02
Hi Maxim!
I'm not sure if the engine oil is good! It is too thin, Brasov likes a thick oil!
Maxim
Re: BRASOV
Post by Maxim » 31 Jul 2008, 18:20
Hi Stef!
Almost all life "old" BRASOV worked on oil 5W40 (all year). Was not problems.
Re: BRASOV
Post by vstef_is » 31 Jul 2008, 18:22
Perhaps because it's much colder for you there in Siberia.... but generally Brasov does not like thin oil. If you had no prolbems then it's ok
Maxim
Re: BRASOV
Post by Maxim » 02 Aug 2008, 17:09
simply fotos...
Maxim
Re: BRASOV
Post by Maxim » 02 Aug 2008, 17:54
Bodylift, that was made in 2000 year, was require disposition change of the cooling tube from radiator to cooling pump..
Maxim
Re: BRASOV
Post by Maxim » 10 Aug 2008, 16:29
The engine before installation...
Maxim
Re: BRASOV
Post by Maxim » 10 Aug 2008, 17:01
in the car...
Maxim
Re: BRASOV
Post by Maxim » 10 Aug 2008, 17:23
Starter "MAGNETON" (Chehia), about it I wrote earlier, to rotate as wild! Very it was pleasant!
Re: BRASOV
Post by Werner » 10 Aug 2008, 17:28
Looks great!  ;)
Maxim
Re: BRASOV
Post by Maxim » 10 Aug 2008, 17:35
It almost ready...
Maxim
Re: BRASOV
Post by Maxim » 10 Aug 2008, 17:40
It works!!!
The first meters....
autom
Re: BRASOV
Post by autom » 11 Aug 2008, 08:24
^:)^ ^:)^ ^:)^ ^:)^ \:/ \:/ \:/ :) :)Bravoo
Misi din Cluj
Re: BRASOV
Post by Misi din Cluj » 24 Aug 2008, 20:22
Great work!  ^:)^ ^:)^ ^:)^
Maxim
Re: BRASOV
Post by Maxim » 26 Aug 2008, 17:43
What for I have repaired car? :-(((  The free time absolutely was gone! :-(((
Not is a lot of about the "new" engine:
Basis - engine with run 20-30 t.km
Replacements:
Piston rings ((GOETZE) 95.0, 08-207200-00)
rod shell (AE; AEB91809STD)
crankshaft shell (AE; AEM91810STD)
The auditing of valves is made, is established new  the mechanism of valves
New nozzles (is marked MEFIN)
The engine is assembled almost without gasket, was used silicon gasket maker.
