Modes of transfer gear-box???
Michael
Post by Michael » 04 Oct 2008, 13:39
I don`t mind. How can work transfer gear-box on my car! How much has mode of transfer gear-box? I need instruction for use transfer gear-box. I have this is kind of transfer gear-box. (looking on pictures)
Re: Modes of transfer gear-box???
Post by Soryn » 04 Oct 2008, 13:51
i think , it's this one
main transmision 1-4 + R , transfer box  4x2= just the rear weels  , 4x4L  = rear end front weels  in slow speed (redus)( loots off torq), 4x4H  front & reear weels  in hii speed(butt  less torq)
poure english
your transfer box , may nott want tu change ghears ,or , it's possible  to ghet stuck in 4x4 mode
Michael
Post by Michael » 04 Oct 2008, 14:02
4x4L How is max speed?
4x4H ?? max speed? up to 100-120km/h???
thanks for the plate.
Post by Soryn » 04 Oct 2008, 14:15
Michael wrote:
CT-03-TVY wrote: i think , it's this one
poure english   ;)
in 4x2 mode,  just in this mode the car chan reach top speed  100-120 km/h
in 4x4H it's not good for the transmision to reach seeds of 60/70 /Km/h
in 4x2L mode,  the car  ,chan reach top speed of 40/50 km/h
THE EXCESIVE Speed It's not good for all transmision parts in movement
in the past my car ,from the excesiv speed, 70/80Km/h  in 4x4H mode,  the front differential  borke down
Michael
Post by Michael » 04 Oct 2008, 14:31
OK. I have one moment. I think 4x4H mode has been broken, because max speed up to 40km/h. If I`ll open transfer gear-box case (cover of hole) then 4x4H is ON? What do you think about it?
Post by Soryn » 04 Oct 2008, 15:07
if the max speed you chan reeach neaw , with the transfer box stuck , is 40km/h,  theat means theat the box is stuck in 4x4L,  you chan acces the visit window (cover)  end look in side,  end you chan adjust the mecanisms, until the ghear stick/transfer box,changes ghears, in 4x4L,4x4H,..end Normal 4x2(back weels)
if the pinion's inside  ar not deteriorated, if they are , you must reconditionate the holle  transfer box
Michael
Post by Michael » 04 Oct 2008, 15:37
I`ve understand. I`ll look inside.
what do you have engine? 1,4? engine block without a crack?
Post by Soryn » 04 Oct 2008, 15:45
Michael wrote: I`ve understand. I`ll look inside.
no  , y have  an 1.6 D vw&audi provenience,  its lowned from vw Golf 1  by the factory,   but the transmision's is the same,  just the cover ,theat conects the transmision to the engine
my 4x4 sistem was dameged , some many yar's ago , my fox, was driving the car then, end now,  i'm triing to rebuild the transmision sistem,... y both the part's  for the front axel,
you dont recongnise my car from yotube site  ,we spoke then ,by email
Michael
Post by Michael » 04 Oct 2008, 16:04
Could you give me link? On youtube.com
I`ve seen there very very much video with ARO.
What is engine name? (in VW or AUDI catalog)
I have 1.4 engine.
Its B14.0 - volvo
and C1J, С2J - renault
Post by Soryn » 04 Oct 2008, 16:18
i dont know wath the engine code is , but in the registration notebook of the car, at engine specifications, says Wolkswagen 827 ,   the same engine was giwen ...to the ww golf 2 ,  but with the code  Jp ,JK, SB alll wih the same displecement ,lyke myne  1588 cc   , but  the fuel sistem is a littel diferent , to produce more Hp,  by exampel, SB engine  1588 cc ,  have  foreced induction (TURBO) end an intercooler ,end the injection phump , haz a  Fuel Regulator  controled by the Turbo actuator, end produces  80 HP,
the engie bloc end the valve train is the same
my engine is normaly aspirated,  end   has  54 Hp ,
morning start, cold   http://www.youtube.com/watch?v=X6OPc3VKGKI
sow, 1588 cc   Diesel  , Engine code JP vw&audii  (is the same,..but my engine dozent have this code becouse is made in Brasil .end imported by the factory  in romania)
Michael
Post by Michael » 04 Oct 2008, 16:32
Oh it`s you. Ive seen video. And I`ve asked you on youtube.
Michael
Post by Michael » 29 Nov 2008, 09:58
Now 4x4 is working.
I have changed position detail up about 2 mm
Thats all !!!
PS. Where I can find universal joint cross of front cardan? Maybe I can find from others europ car?
Post by Soryn » 29 Nov 2008, 12:15
Michael wrote: Now 4x4 is working.
Thats all !!!
nice work pall :>- ;)
i hope you flush the rusty oil(brawn)  from the transfer box,end stuk in to it   new fresh transmision oil,becouse look's bad, ::) :>-
Michael
Post by Michael » 04 Dec 2008, 19:47
of course! I`ll use new transmission oil
