Aro 10.4 in Macedonia i need help for parts and other stuff
Moderator: UMMM461
icemann
Re: Aro 10.4 in Macedonia i need help for parts and other st
Post by icemann »
SorinTVY wrote:It's on the ciken mind that will be independent play,diff,transfer case,ghear box
sorry i didnt understand you??
If the dif i's new, butt transfer box worn owt,you still wil have power delivery laps. becouse of the dif play+ transfer box play + transfer box play..
serch for shaft play...mining.
icemann
Post by icemann »
I have fixed the play in the diff :)
i`ve removed the intermediary-bearing-propeller-shaft the rubber doesnt hold the shaft. so i am planning to take it to the guys who mold rubber. but i cant seem to remove the bearing from the axle... i`ve unbolt the large bolt that holds the bearing but it doesnt seem to move.. i dont know what is the procedure to remove it whole.. so i might leave it as is.. the bearing seems ok.
icemann
Post by icemann »
i need help fast.
nobody knows how to remove the bearing/rubber from the shaft?
there is a washer they removed the washer but dont know how to remove the bearing with rubber.
icemann
Post by icemann »
i`ve managed to remove the part.. i should finish the repair today.
icemann
Post by icemann »
i was wrong...
i got the part and it was terrible.. like a 3 year old without brain was molding the rubber.. http://s1.uploads.im/b9M4p.jpg
http://s1.uploads.im/k04UG.jpg
http://s1.uploads.im/ckfpb.jpg
http://s1.uploads.im/o1cUW.jpg
http://s1.uploads.im/BJw5W.jpg
i`m now without the part and i doubt if there is anyone in Macedonia who can mold it without negative mold which costs around 200 euros... and my aro is in the garage :(
HA HA HA , custom ruber bearing holder.
Find a local salvadge yard, take a look in the drive shaft's they have there stak't , adapt other damper. Slightly adjusting it with some washer's end a metal bushing (custom made )
Braket of the charier ,you chan adapt it wit some metal plate or somthing.
icemann
Post by icemann »
http://www.aro-10.net/en/transmission-a ... shaft.html
i was thinking of buying this..
is this second hand? or is it worth the money?
icemann
Post by icemann »
Sorin please give me info is this site ok to buy from?
i would like to buy this part new.. the junk that we have here is worse than my old rubber it will take alot of money to adapt and they sell junk stuff at price of new..
one guy asked 50 euros for rubber from a van, that was able to adapt somehow.. that is to much..
The online store ,it's like a no name store, i downt know if it's ok to buy from them or not.
+ the price i's delirius.Buy the way on the online part's store ,the guy it's saling new but old parts( the spare part's manufacturer i'ts history, like almoust all romanian industy) .
Know these days we find new but old parts on the free market ,like this one http://www.tocmai.ro/rulment-intermedia ... 75769.html
the price there it's about 40 usd ,with no transport, the ruber mount i't chan be delivered by national mail service in other location in romania, end from there chan be mailed to you with a 2 end price of pakage.
Depend's if you got about 60 usd for the part end transport.You decide.
Otherwais we chan not heelp you ,just if you want a second hand part, that will be cheaper.
icemann
Post by icemann »
well, if there are good second hand parts why not.. my rubber was old.. it didnt hold the shaft on the center it was laying on the bottom of the metal ring..
how much are aprox second hand..
60 usd is like 45 euros.. that is not that bad.. i`ll check for transport costs.. how much does it weight? around 1kg?
icemann
Post by icemann »
http://www.posta-romana.ro/en/posta-rom ... itare.html
ive checked this site and the macedonian postal site.. the transport from macedonia to romania is around 10 euros.. i guess from romania to macedonia is something like that also..
that is not a problem..
if you can help me with a part i will transfer money first and i`ll be very thankful.
i`ll be searching on a junkyard in here that has one old white aro Mk1 but i am not quite sure that it had rear diff or shaft or rubber..
and if i find it it will be in bad condition as mine was..
so the solution is to find a good part new or old.. and someone nice to send it from romania.
icemann
Post by icemann »
today is a sad day for me.. i`ve broken the same gear that i replaced few months ago with one that a company made it for me. apperently the quality is bad and the gear broke. and there is a hole in the box which i`ll have to weld again.:(
so now i am again in the garage.
i removed the engine and box.. there was play in the transfer box.. but nothing else is damaged.. so i`ll need a new gear.
does the old aro mk1 (sorin there was a white one from the junkyard) does that has the same gear? or i`ll have to order it from Romania.. :/
and while the engine was out i was testing it on the bigger renault 19 engine 1.8. from my uncle. but it seems that the flywheel doesnt fit buy very little. is there a fix for this?
i was thinking to get it to a machinist to make the hole big for the flywheel. i think it will fit like that but if they make it wrong i will not be able to go back.
any info about this two things will be great..
thanks
The old mk1 car it's the same sprochet ,butt i'ts not sow wide like yours, i't is 17 mm wide teeth on it ,I think, yours has 19 mm. It chan work like that.
Serch if the R19 gas engine block,has the same patern like the R19 f8q 1.9 Diesel engine.
Yo chan swich the cluch housing ,with the aro 10 1.9 D housing.It's a little bit triky with the oil seal ,other wise it's bolt on to your ghear box.
icemann
Post by icemann »
yes mine is 19 or 20 mm.. i will check if the white aro has the gear still in one peace..
great about the 10 1.9D.. but i cant find 1.9d housing :S
