Scwimmwagen
- Misi din Cluj
Scwimmwagen
Iata ce am gasit!
Estepe mecanica de Vw Broscuta!
Stiam de existenta sa, dar prima data, cand vat poze asa de detaliate cu asa ceva!
M-am gandit, ca trebuie neaparat s-o vedeti si voi!
http://www.classicvws.com/sale/water.htm
- Misi din Cluj
Re: Scwimmwagen
Sunt o gramada de poze acolo
Re: Scwimmwagen
super...dar cat costa
am vazut odata un documentar despre ele pe discovery,in urma cu 2 ani.
cand esti bun nu-si amintesc,
cand esti rau nu te uita
- Elijah
Re: Scwimmwagen
Kettenkrad, jumate automobil senilat, jumate motocicleta
- Misi din Cluj
Re: Scwimmwagen
- Misi din Cluj
Re: Scwimmwagen
- Misi din Cluj
Re: Scwimmwagen
Oare, Kettenkradul cum se conduce?
Din ghidon sau din manete, ca senilatele?
Cred ca avea ceva directie mixta, ca altfel ar fi greu de manevrat!
- Elijah
Re: Scwimmwagen
chiar, buna intrebare. Banuiesc ca asa cum sugerezi, mixt. Dar nu cred ca din manete ci mai degraba din pedale....Ar fi complicat sa tii si ghidonul si manetele la viraje
- Misi din Cluj
Re: Scwimmwagen
Niste date tehnice cu dracia asta, unde pot gasi?
- Elijah
Re: Scwimmwagen
Technical Data of the NSU Kettenkrad
The Kettenkrad was designed as a small tractor (prime mover) to tow a trailer or a small gun (20 mm AA or 3,7 cm AT).
It carries a crew of three soldiers. The driver and two passengers. The passengers are facing backwards.
The Kettenkrad is not armo(u)red and not armed. Some versions have three riffle holders to carry the riffles of the crew.
Manufacturer NSU Motorenwerke AG, Neckarsulm, Germany
Type HK 101
Military type Sd.Kfz 2
Measures and weights:
Length 3 metres (118")
Width 1 metre (39")
Height 1.20 metres (47")
Unladen weight 1235 kg (2726 lbs)
Payload 325 kg (717 lbs), including driver
Combat weight 1560 kg (3444 lbs), including crew of 3. Only 95 kg (210 lbs) of this weight is carried by the front wheel, the rest is on the tracks.
It is a small vehicle
Driving performance:
Top speed Driver's manual says 70 km/h (44 mph), other sources say
80 km/h (50 mph), postwar title says 61 km/h (38 mph)
It is fast...
Engine (Motor):
Manufacturer OPEL (German daughter company of GM)
Type Four cylinder in line watercooled OHV engine
Capacity 1478 ccm
Bore 80 mm
Stroke 74 mm
Compression ratio 1 : 6
Performance 36 bhp (26 kW) at 3400 rpm
Carburetter SOLEX downdraught off-road carburetter 32 FJ-II
(The first 500 Kettenkrads and all postwar Kettenkrads had a standard OPEL (System Carter) carburetter)
Electrical system: (Thanks god, it's BOSCH!)
Voltage 6 Volts, negative ground
Generator 6 Volts, 75 W
Battery 6 Volts, 75 Ah
Spark plugs BOSCH W145T1 (today: W8AC)
Firing order 1 - 3 - 4 - 2 (Cylinder 1 = At the rear, water pump side)
Contakt breaker point gap 0,4 - 0,45 mm
Ignition timing point 30° before t.d.c. (full advanced)
Suspension:
Front wheel 3.50-19 (Air pressure: 1,7 atü = 25 psi)
Tracks Zpw 51/170/120, 40 links per track
Track pads W02
Wheels Road wheels 450 mm diametre, Leitrad 410 mm diametre. (Very early Kettenkrads have bigger Leiträder)
The engine comes from the well known OPEL OLYMPIA car. NSU was a motorcycle factory and produced only one cylinder engines with up to 600 ccm, which were not powerfull enough for the Kettenkrad. To save the work and the time for the developing of an own engine, NSU took the reliable OPEL engine from the stock. The OPEL OLYMPIA car was in Wehrmacht use, too, so the mechanics in the field knew the engine.
Gearbox:
Gearbox with 3 forward gears and 1 reverse gear, plus transfer box for "Gelände" (Off-road) und "Straße" (Road). So in total there are 6 forward and 2 reverse gears.
Fuel consumption:
On the road: 16 litres/100 km (18 mpg (imperial))
Off road: 22 litres/100 km (13 mpg (imperial)) and more, depending on the terrain.
The fuel tank capacity is 2 x 21 litres. So each of the two fuel tanks can take a full jerrycan. The fuel tanks are located to the right and to the left of the driver.
Type HK 101
Width 1 metre (39")
It is fast...
Engine (Motor):
Capacity 1478 ccm
Bore 80 mm
Stroke 74 mm
Suspension:
Track pads W02
Gearbox:
Fuel consumption:
- Elijah
Re: Scwimmwagen
Se pare ca roata ii asigura stabilitatea la viteze mari, la offroad adica la viteze mici de deplasare, nefiind necesara.
Uite schema directiei!
- Misi din Cluj
Re: Scwimmwagen
Interesant si ingenios!
Directie cu ajutorul a doua frane cu banda.
Oare cat timp tin ferodourile alea.
La mine pe Aro 10, frana de mana actioneaza pe cardan, printr-un dispozitiv asemanator. La Gaz 69 si Uaz la fel, tot asa ceva!
- Misi din Cluj
Re: Scwimmwagen
Am gasit niste filmulete, cu tanculetu’ un actiune:
http://www.youtube.com/watch?v=InMraz1iqbA
Si aici site-ul oficial, cu o gramada de poze si filmulete:
http://www.kettenkrad.de/
- Elijah
- Misi din Cluj
Re: Scwimmwagen
Interesanta comparatie intre Vw Schwimmwagen si Gaz 46MAV.
Intre ele, titusi exista o diferenta de 20 de ani.
Gazul 46, pare sa pluteasca mai bine.
La o astfel de masina intrebarea pricipala este ca pluteste sau se duca la fund?
