PARTS COMPATIBILITY FOR ARO10 Please help
- icemann
Re: PARTS COMPATIBILITY FOR ARO10 Please help
i`ve added cheap led lights, don`t know how much they will hold but it is what it is..
i`ve bought new 15 inch rims for 100 euros, and drilled new holes for 50euros.
total 150euros. i also bought second hand tires, this is just temporary, i wold like to buy ones that i can use for offroad.
these are 205 75 15 Bridgestone dueler H/T
- icemann
Here are some more pics from the exterior,
i will have to manufacture fenders, something simple... i still have to fix the brakes, and the steering is very hard.. i have rebuild the joints... and they are very tight.. and i have to take it to a computer aligning becouse the front wheels are not centered. i will post pics some other day..
- icemann
I did some work in the enterior...
i removed the ashtray and created a starter button.. i will post better pics later.
and because somebody broke and welded the steering wheel i bought new one.. i was not able to find one from aro instead i bought a wheel from subaru impreza 96-97.
- icemann
i have bought lights for the roof but still have to figure how to mount them.
sorry for no ''advice'' ,i was detatched in germany for a period,icemann wrote:sorin i`m trying to fix the brakes but i have problems with the main cylinder or break pump... i need schematics i think i made mistake with the rubber parts in the pump..
i need some assembly schematics in order to fix it..
thanks..
For the brake phump,in romania wee replace the old aro phump, with the another one ,the newer model instaled on aro 10 at the latest models.
with the new phump you need to replace the servo vacum mecanism of the phump to.
modification needed for the servo mecanism are nott a big deeal,the adapter flanje original one needs to grind down the weeld end rotate the the flanje a few degrees ,end reweld the flanjes togheder.At the brake pedal need smal adjusment too.After the upgrade you will have realy brakes not a joke.
The phump end servomecanism is from ford escort older models 90-99 somting like this.
heare is a topic with the phump,end some codes for it.
http://www.aro4x4.net/smf/viewtopic.php ... 9&start=30
- icemann
Hey sorin I think that now I have fixed the breaks with r19 break pump and servo. . I did the same adjustments to the servo spacer. I need to test it but I think it works. What do you think about the other stuff ij the pictures. Also is it ok to pit 10 40 syntetic oil?
Thanks for replaying I tought I was anoying
- icemann
i have 10x40 Castrol sintetic oil. is it ok to put it on the aro or i need something half sintetic?
engine wear? the engine is desined tested with old tipe of oils ,the engine wil work with eny kind of petrol engine oill,if the engine has some miles on it , oil pressure is not at his best,becouse of this 10w vascozity cold number is minimum to use,in other words the engine needs thick oill. 10w40 is fine ,bad cuality oils will create sludge in the engine ,end the carbureto will ghett stuck (recicling lost compresion from the engine/sludge).
the problem with the engine is the carb sistem, end spark sistem, end valve adjustment, the sistems,are in need to be ajusted propely , if not , the engine wil work bad.
- icemann
ok than, i will buy 20W 50 or 15w 40 as on the specifications..
winter it wil arive sun, 20w50 is too thick for cold start in winter, winter period 10w40 will bee perfect.
some guys in romania are testing 10w60 in there engines, motttul, the bad thing is the price,costs x2 regular 10w40oils
- icemann
i bought 15/40 and changed it with new filter.. all liquids are changed now..
i paid for registration and now the aro is legal to drive.
i need to finish with th enterior, the heating fan was loud and squeaking so am changing it with one from maruti. i`ll make some modifications, also a bought some switches from Oltcit now i have to make modifications on the connectors and finish with that...
after this winter i`ll continue the story of making my aro look, and run better
heating fan,the electric motor has no berings,the rotor is working on bronze buschings,when is runing out of grease, starts squiking.
if you chan,instal a larger blower, or repair the old circuit, for the front window, end mount auxiliar blower under the dash.
- icemann
can you send me a picture of an modification on a auxiliary fan?, since i`ve changed the water with antifreeze i don`t have flow to the radiator under the dash. i assume there is air in the system..
auxiliar heating blower , in your car you need to mount it more to the pasager side(if you find somthing like this), becouse will hit in the transfer case lever knob
first 2 pics. http://www.aro4x4.net/smf/viewtopic.php ... 2&start=90
- icemann
i will try to go only with the main one. i should post some more pictures so i can get more great advice for the aro.
thanks alot Sorin
thanks alot Sorin
