CD-uri, fisiere cu manuale de reparatie ARO, de pe internet !
- eltalivan
Re: CD-uri, fisiere cu manuale de reparatie ARO, de pe inter
Raportul fişa de date .. de viteze cu 5 trepte cutie (5 +1) şi repararea de tansfer Aro 10.4 ..... Multumesc
we have some schematics end 2 repair manual for the 10.4 mk1 ,mk2 , both have 4 speed ghear boxes, butt the transfer box is similar with yours, wee have some schemattics wit the 5+1 ghear box but renault tipe,named N05 , aro 10 in time 1981 -2004 , the transmision parts ar nott all the same, deppend's watt tipe of engine is on the car!
4+1 sped ghear box RO tipe with trasfer box including reduction ghears
5+1 RO made ghear box with trasfer box including reduction ghears
5+1 Ro made butt without the transfer box onllii 4x2 (power on reear axell)
5+1 Made by Renault -Modified in Ro for the transfer box (this ghear box have a renault code by the passager side on the aluminium housing)
this ar the common ghear boxes used!
you chan make some pictures undher the beelly of the car, en upload in your topic , soww wee chan see exactlly watt transmision tipe do yo have!
La adresa http://fbx.ro/5kndxcql1mbvukct este disponibil catalogul de uzina pentru Aro 10.(piese componente)
Este in romana, franceza si engleza, simultan.
Din cate imi dau seama e pentru motorizarile diesel Renault dar se poate folosi si pentru celelalte motorizari.
Valabil urmatoarele 29 de zile, cat un mandat de arestare !
La rugamintea colegului uivil10 am pus la adresa http://fbx.ro/34b852ncgp4tu8rg manualul de reparatii pentru Aro 24x motorizari L25, L27 si D127.
La adresa http://arotrappeurs.e-monsite.com/pages ... iques.html este disponibila permanent documentatie pentru Aro 10 motorizare 1.4 benzina.
- Kostan
Thank you! Finally I know the types of gearboxes ARO10!SorinTVY wrote:We have some schematics end 2 repair manual for the 10.4 mk1, mk2, both have 4 speed gear boxes, but the transfer box is similar with yours, wee have some schematics with the 5+1 gear box but Renault type, named N05 , ARO 10 in time 1981-2004 , the transmision parts are not all the same, deppend's what type of engine is on the car!
4+1 speed gear box Romanian type with trasfer box including reduction gears
5+1 Romania made gear box with trasfer box including reduction gears
5+1 Romania made butt without the transfer box only 4x2 (power on rear axell)
5+1 Made by Renault-Modified in Romania for the transfer box (this gear box have a Renault code by the passenger side on the aluminium housing)
this are the common gear boxes used!
You can make some pictures under the beelly of the car, and upload in your topic , soww wee can see exactlly what transmision type do yo have!
Multimesc! În cele din urmă știu că tipurile de cutii de viteze ARO10!
Eu am permis să facă unele ajustări cu Google Translator. I allowed myself to make some adjustments with Google translator.
Best regards. Salutari.
- Kostan
Mulțumesc. Aceasta este o informație foarte valoroasă! Salutari.vercingetorix wrote:La adresa http://fbx.ro/5kndxcql1mbvukct este disponibil catalogul de uzina pentru Aro 10.(piese componente)
Thank you. This is really valuable information! Respect.
- Kostan
Iată o fotografie de echipamentul meu "APO 10 -. Dacia Duster" Anul - 1988. Motorul de 1,4 litri pe benzina, carburator. Gear 4 +1. O unitate plug-roți, există o crescută și o scădere a numărului de transferuri. L-am reparat cu mâinile lor. Știi ce tip este o transmisie? MultumescSorinTVY wrote:you chan make some pictures undher the beelly of the car, en upload in your topic , soww wee chan see exactlly watt transmision tipe do yo have!
Here's a photo of my gear "APO 10 - Dacia Duster." Year - 1988. Engine 1.4-liter petrol, carburettor. Gear 4 +1. A plug-wheel drive (part-time), there is an increased and a decreased number of transfers. I repair it with their hands. Do you know what type it is a transmission? Best reards.
- Kostan
here's another photo
- Kostan
it's a 4 speed box, with transfer box , 4X2, 4x4H , 4x4L , N
- Kostan
Mulțumesc. Te-am înțeles. Î: aceasta este un standard (comun) caz, acesta nu este special (propriu) numele și indexul sau codul?
Deoarece această casetă este indicat în cataloagele?
Thank you. I understand you. Q: this is a standard (common) case, it is not special (own) name and index or code?
As this box is indicated in the catalogs?
4 speed box is the same ,at all cars,with the 4 speed , you don't have the manual?
- Kostan
"4 speed box is the same ,at all cars,with the 4 speed" - this is the most important thing!
"you don't have the manual?" - unfortunately I have no manual
all we have for aro 10 11 , you have there an owners manual,1.4 1.9 D to
http://dl.transfer.ro/transfer_ro-08feb ... 232a59.zip
