10.4 parts? Looking for...
DangerCell
Post by DangerCell »
96' Aro 10.4 1.9d, looking for:
1. Repair manual
2. tie rod ends
This image id for mahindra jeep but need these articulation points for the aro 10.4
Usually the whole end is installed, however on the aro, the articulation joint is held in place by a "C" clip....so maybe they sell just the articulation joint???
3. Oil seals for front "transfer case" (gear box where drive shafts for front wheels come from).
4. Oil seal where drive shaft enters rear differential (where drive shaft goes into rear axle)...it is leaking steadily
5. c.v. joint boots/seals and possibly the c.v. joints themselves
Hope i can bring this vehicle back to full potential! Thanks in advance for your help!
DangerCell
Re: 10.4 parts? Looking for...
Does no one know where to get any parts????
madluis, the links you posted were extremely helpful! THANKS!!! But there are some that I need that are not there :(
Where are you from?
DangerCell
I am from U.S. but live in Portugal for half the year...you?
icemann
Post by icemann »
DangerCell wrote:I am from U.S. but live in Portugal for half the year...you?
Hi, DangerCell.
I as you have problems with parts from my aro.
i tried the local shops and had success with some parts as they are interchangeable.
the Oil Seals you can find them in shops that sells bearings and seals. just remove the old one and make sure you dont damage the numbering.. or show it to the salesmen they usually have broad range of seals.
for the tie rods i got them to a guy that does restoration to tie rods but that makes them very hard and i dont recommend it. but if you take it to a guy that does that there is a chance that he finds you new tie rod ends. i think they are compatible with Dacia and Renault.
but not sure which model.
Best of Luck.
Garrettpymn
10 4 parts Looking for
Post by Garrettpymn »
Hi, Im looking for a programmer/developer that can build a CasparCG Client Software for us. Who to contact to send a general description of what we need?
https://www.levitradosageus24.com
