I need information about adjustment of "clutch bearing"!!!!
Please, tell me. What is "clutch bearing" clearance? Or maybe without it???
I`ve attached photo for help
Adjustment of "clutch bearing"
- Michael
- Ionut
Re: Adjustment of "clutch bearing"
As far as I know, you just put the bearing there and do nothing else. After you'll put the engine and gear box together, you'll adjust the clutch cable and that's all.
Stand or die.
- Michael
Do you mean clearance between "clutch bearing" and "basket chaining" is absent.
And "clutch bearing" and "basket chaining" is roll together all the time???
I`m right?
I`m right?
- Michael
What do you think its a normal condition after 98000km running?
yes the condition is normal or very god
- Ionut
You might find a bush to put on the plate where the bearing gets in contact with it, to prevent further wear, but this is at Dacia engine. I don't know if you find for Volvo (if you have this kind of engine)
Otherwise, if the surface where it meets the disc is fine and has no groove, it's all right.
Stand or die.
Change, 98000 km Is enough.Michael wrote: What do you think its a normal condition after 98000km running?
- Michael
All is good.
I have new...
cost about 35 EURO
I have new...
cost about 35 EURO
