Hello from USA
Presentations,questions,everything...only in english language,please
Moderator: UMMM461
1989 ARO 244
Hello from USA
Post by 1989 ARO 244 »
HI owner of a 1989 ARO 244    I need trim pieces and info on A frame bushings, and a turn signal relay.  Powered by a Ford 2.3 litre.  Cheers  Terry
Maxim
Re: Hello from USA
Post by Maxim »
Hi Terry!
Can You more widely set a question?
What problem with a frame bushings?
What problem with a turn signal relay?
Yes... Worldwide have run up ... Even up to USA :)
1989 ARO 244
Re: Hello from USA
HI  sorry for the broken english.
My a frame bushings are shot, broken, need replacment.
the turn signal relay will not work.  it has around 11 wires hooked to it, and it is red, and a large square shape.
markings on relay
94251      1088
12V(2+1)X21W+3W
MADE IN ROMANIA
THANK YOU Terry
Maxim
Re: Hello from USA
Post by Maxim »
Hi Terry!
It is  connection circuit and internal circuit the turn signal relay.
1989 ARO 244
Re: Hello from USA
Yes  that is it.....where can I find a new one?
Maxim
Re: Hello from USA
Post by Maxim »
Hi Terry!
What for new? ???  :-??
*-:) Repair, which is having. It is very simple.
Likely, the reason of malfunction not in the relay, in electrical wire circuits.
Check up a feed voltage (on 49) and connection with body (31),
connect a lamp between 49a and car body.
If relay will not work, disassemble, itself or with whose help, repair the circuit of the generator of pulses, or solder instead of the "native" circuit, circuit from ANYONE car (only from 12 volts), having placed the "new" circuit in the "native" case :-"...
Probably, new, is not has been find...
1989 ARO 244
Re: Hello from USA
ok thank you  I will try to repair it.  I have not had it to work since I have owned ARO..  The drawing will help very much    Terry
Now for the bushings....do you know what else they fit?
Michael
Re: Hello from USA
Post by Michael »
1989 ARO 244 wrote: HI owner of a 1989 ARO 244    I need trim pieces and info on A frame bushings, and a turn signal relay.  Powered by a Ford 2.3 litre.  Cheers  Terry
This car is a good work for Chip Foose :)>-
pantelimon
Re: Hello from USA
Post by pantelimon »
HELLO USA!!
HAVE A SUME PICTURES UITH OUR ARO
